Hello I have just purchased the lytmi 2.0 sync box and was wondering about setup. My tv has removable panels along the bottom edge so you can access cords, thus I cant run a cable along the bottom edge without restricting access to said cords. How should the light strips be set up if I only want light on the sides and top.
Hi Richard, sorry but it's designed with algorithm, so it has to go to the bottom side. Can a detour of lights solve the problem?
I figured it out. I didn't notice that the light strip is easily removed from the brackets allowing me to still have access to the back panels. Thank you for your response, the product is working fantastically.
Great to hear that
