Hi, could I use the lytmi neo led as an ambient light without the “syncing” function while tv is off or while I’m using any tv app? (As if it was a simple lamp). Sometimes I just need a simple light on the back of the tv.
I believe you could select different modes on your your phone APP. If you do not want it to sync with your TV, you could choose the taste mode on the APP:
Sure you can.
