    Howard Vo
    Dec 22, 2021
      ·  Edited: Dec 22, 2021
    Better Neo light strip controls soon?
    Are there any plans to refine the Lytmi app in the near future? Your competitor, Govee, allows users finer control of their backlight LED strips.
    Some of the useful features are relative brightness control of different segments of the LED. There are 10 individually controllable brightness zones. 3 zones each on the top and the bottom of the TV and 2 zones each on the left and right.
    Many of us mount our TV's at an angle so the bottom parts of the light strip is much brighter than the top. The brightness at the bottom is almost hard to look at while the top LED strip is very faint.
    Additionally, Govee also has LED color saturation controls. This addition into the Lytmi software would be great for better color matching LED's to our screens. It may also be a work around for the users experiencing washed out colors in HDR mode.
    1 comment
    Dec 22, 2021
    That's so constructive suggestions, thanks for that, we will definitely take that into consideration.
    1 comments
