Hi! I connected the App and everythings should work as i can see in the app, but the light wont change, and i´m only getting light in the corner. whats wrong? When i restart everything i get a blinking over the whole led strip. The led strip is connected in the app.
Please reconnect the sync box. After all the connection, please unplug the power supply and re-power it after 10 seconds. Let the box reactivate.
May I kindly know if the light strips will turn on and go around after it had been connected and powered on?
Plus, may I also know if you have used USB extension cables? Could you kindly disconnect the extension to check if the light will flicker as well?
If it still does not work, please contact our support email for the aftersales service.
