How do I connect the Neo hub to Google Wifi. There is no way to select between 2.5 or 5. Most smart devices will automatically select the 2.4 but not Neo. The Tuya app is not locating the device either.
I think mine worked by connecting my phone to the guest network before starting the setup process in the app. By what I read, the Google WiFi guest network defaults to 2.4
What app are you using? I ditched the Lytmi app and used Smart Life was able to adopt the box without issue
It's a real shame it doesn't work on 5
