    Mark McG
    Dec 20, 2021
    Consistent Information please
    Hi @Jack
    I appreciate that you guys have tried to keep us updated regarding the Dolby Vision &HDR challenges, but I am confused at the different messages regarding HDR, Dolby Vision and we need to use splitters etc and yesterday I got a message from support@light-mi.com saying "The latest firmware can support Dolby Vision without the splitter"
    Is there a way that you can either update the forum in a specific area as things change - or make sure we get the same messages from support and the forum?
    I am now totally confused as to what I will get delivered? what features it will support? how long the LED strips will be? Will the HDR reduced colours be disappointing? Would things be better with a splitter? What would the splitter need to do?
    Maybe we need a FAQ section?
    16 answers9 replies
    Dec 22, 2021
    For Dolby vision, it only works with Splitter for the time being and we are trying to find the solution without using the Splitter, but right now the answer is still negative. For HDR, we are still working to get it more saturated than the current "whiter, lighter, and paler", though it's unarguably caused partly by the inherent feature of HDR, but it's still a problem for all the lytmi customers and for ourselves also. For the shorter light strips, this is found only with the 65''.
    For the corresponding solutions:
    DV: offers a free splitter, 15% lifetime discount or contact our support team(support@light-mi.com)
    HDR: the HDR is indeed lighter than SDR, so if you can't accept that fact, contact our support.
    Shorter light strips: contact our support.
    KeKyKo
    Dec 24, 2021
    HDR files are very vivid. But DV files don't respond correctly. The colors are all wrong. Here is a DV file. All DV files are like this. But non DV HDR10+ & HDR play normally.
    Alexander Smirnov
    Dec 24, 2021
    @KeKyKo thank you so much!
    That means that 1.4 is better than 2.0 because it gives better colors for HDR10+/ HDR10/ HDR.
    I guess developers moved in the wrong direction with 2.0.
    Per Plex
    Jan 11
    After send back this not working as advertised product today i got my money back!
    Per Plex
    Jan 12
    de.aliexpress.com
    99.4€ 38% OFF|Smart Umgebungs TV Led hintergrundbeleuchtung Für 4K HDMI 2,0 Gerät Sync Box Led Streifen Lichter Kit Wifi Alexa Stimme google Assistent Control|LED Strips| - AliExpress
    Smarter Shopping, Better Living! Aliexpress.com
    Did you see what i see 🤣
    Catherine_England
    Dec 20, 2021
    Lytmi's communication is pretty poor isn't it. It's more confusing than anything. Is there an update to download via the app?
    markmcgo2
    Dec 20, 2021
    I did ask how I would know whether I was on the latest update or what release number they reckon includes the fixes. No response so far.
    Alexander Smirnov
    Dec 20, 2021
    Same here. It seems like support hasn't been informed about Neo 2.0 issues.
    I got my NEO 2.0 box and haven't even opened it yet because other people have so many problems with HDR. I'll just return it back in a week or two if HDR lighting won't be solved or at least have a solution.
    It's just sad that NEO 1.4 version with splitter has a better HDR performance than Neo 2.0.
    Will HDR low contrast colors ever be solved for first buyers? What splitter will actually do for TV and for lighting? What is an actual latency (because it's not "Zero latency")?
    Support mostly gives us answers about things that we can read on the box or website. ourselves.
    Mark McG
    Dec 23, 2021
    My Neo 2.0 kit etc arrived yesterday - but as there seems to be several unresolved issues with this product compared to what I thought I was getting I have mailed support@light-mi.com requesting a return of my Neo setup.
    Currently waiting for response - will keep the forum posted on what happens
    Per Plex
    Dec 23, 2021
    They will tell you, you can't send it back because policy 😂
    Mark McG
    Dec 23, 2021
    Any response will be good so I can then move it onto a Paypal dispute
    Matty UK
    Dec 23, 2021
    Be careful. They aren't throwing straight dice. They told me as the item had been used I couldn't return it. Then when I said that's against the law they said I could return it but read their returns policy. (The returns policy isn't throwing straight dice and doesn't abide by the law) I replied saying, but you said I couldn't return it if used. They replied saying I was correct and I couldn't return it if used. See I feared if I sent it back like they claimed in their second reply email they'd end up just saying "hey it's been used no refund for you".
    Mark McG
    Dec 23, 2021
    Thats exactly why I am not even going to try to install it - I have just opened the box to check the contents and photo what was in the box - checked that the LED strips where 200mm short etc. I think your point is valid in warning people that this is a product that 'may' not be satisfactory when compared to what was promised and therefore do not attempt to install it if you have any doubts in the product performance.
    Per Plex
    Dec 23, 2021
    same as i did, the product is not used like they think...i now waiting for an answer where can i return the box.
    Hancock Jose
    Jan 07
    Algunos no sabíamos de este problema y instalamos el producto (quien iba a pensar que un producto diera esos problemas, cuando su anterior version 1.4 funciona bien), mis tiras se ajustan bien a mi tv 65", y las luces funcionan con la aplicación manual, el problema es cuando quiero ver películas en 4k, dv, hdr, ...... que las luces no se encienden. No devolvere el producto por que mis tiras estan usadas, pero si pediré un reemplazo de la caja 2.x cuando este actualizada, espero que acepten esta petición, seria lo correcto, cambiar una caja por otra.... y todos contentos.
    Per Plex
    Dec 23, 2021
    The product is used but it does not work as advertised so it is a kind of cheating funny that they can offer their splitter so quickly they must have already had ready. This all looks to me like a rip-off and they want to talk themselves out of it with the policy but that will not work.
