I’m using the Lytmi app to control my neo 2.0 setup. But in the description for using Alexa (Amazon Echo) it says to use the light mi app and the skill Smart Life in Alexa. I’m already logged into the smart life skill with another account to control some other devices. Is this the only way?
top of page
Controlling neo 2.0 with Alexa help pls
3 answers0 replies
Like
3 Comments
bottom of page
Hi All
Is it possible to switch with Alexa from Color to Video Mode ?
I can't find a Command.
Remove your lytmi light from the Lytmi app. Delete the Lytmi app. Install Smart Home and adopt the light there. You will be able to integrate into Alexa/Google Home
This is what I personally did
We have the exact same issue here, and we have the Lytmi Neo 2.0 lights too. We are still looking for a solution though…
