I figure that the new lightstrip with the diffusor has a limited bendability. For my Sony TV, since it's mounted pretty close to the wall, I may have to mount the lower side to the bottom box of the TV. I expect it to be difficult to twist and bend the strip around that.
My question is: Is there a way to cut and reconnect the strip with a short cable for a few centimeters so that this transition is easier? Maybe even ready-made connectors?
Thanks for any hints!
Theoretically speaking, as long as you cut the light strip correctly and the light strip is not damaged, it can be reconnected. But I am afraid that this involves some professional technical problems in welding.
I do not recommend you reconnect the snipped light strips, and the synchronization may cannot be guaranteed.
