Does anybody tested this Splitter (https://feintech.eu/en/products/vsp01222-hdmi-2-0-splitter-2-eingange-2-ausgange-mit-arc-pass) to get work with the Neo Box 2.0? This Splitter fixes the ARC-Problem, CEC is also working, but the Neo lights are not working. I do not understand why not. Maybe a problem that there is no cable connected at the output of the Neo Box? Anyone have an idea?
Dolby Vision and HDR is not implemented for correct lightning! So this won't work anyway. To fix the ARC problem you can use the optical out from tv to avr or use the 4k splitter from ezcoo.
HDMI Splitter 1 in 2 Out 4K 60Hz 1080P 120Hz 4:4:4 HDR D-olby Vision D-olby Atmos Scaler 4K 1080P, Firmware Upgrade HDCP2.2, Scaler EDID Switch, USB Power https://www.amazon.de/dp/B083JVPXDY/ref=cm_sw_r_apan_glt_i_K6HP6RPVTPKGVQBZG237?_encoding=UTF8&psc=1
The problem with the optical cable is that you are degrading your audio quality by a lot
Ok, good to know. Then I will send the splitter back. Thank you so much for this information. I'm still waiting for the splitter from Lytmi. It's already on the way to me. If this splitter don't work for me, I will order this Ezcoo splitter and resolve the ARC with the optical cable, as you suggested. Thanks again!
I'll think the lytmi splitter never finds the way to Germany.😁😂
My splitter already departed from airport of origin country. I hope it takes not so long.
I will hope the splitter you get from LytMi supports downscale for the ambilight HDMI in.... This will end up in better colors and transitions with 4k source material. But there is no way to fix the wrong or not implemented HDR and DV color correction.
Hope so also. I will tell you, when the splitter arrive.
