I tried to connect the NEO box with Alexa but Alexa can't find the NEO box and on top I can't find a working skill??!
ย
Nov 22, 2021
How can I connect to Alexa and where can I get the Alexa skill?
3 answers2 replies
ย
I figured it out: you need to use smart life app instead of the Lightmi. it works well with Alexa and other software that has support for Tuya IOT Platform.
Thx for your advice. Yesterday I solved the problem too ๐๐๐ป
I attach the guidance in PDF for your reference.
you have "app name" in the PDF. It's the same in the guide in the app. I think you forgot to replace it with an actual skill name when you received this guide from tuya. Can you tell us what the actually skill name is?
I see this still has not been addressed. What is the app name in Alexa skills for lytmi?
