I decided to return my Neo Pro 2.0 kit based on reading various complaints around HDR support. My primary use case is Xbox Series X to LG CX and it seems like the 4k/120hz/DolbyVision/Atmos that I'm enjoying won't work so well with this setup. Thankfully, while I opened the box, I didn't unpack any of the components or make any cuts. I reached out to customer service via email last week to start a return, but never heard back. I then came across the return portal (https://ilytmi.com/a/returns) and submitted an RMA on 8/15, but I haven't heard back from lytmi. Has anyone else had success getting a return/refund? What sort of turnaround time should I be expecting. I'm used to these types of companies being quite responsive, but perhaps I've been spoiled.
Thanks!
Hi Leo,
I believe Neo 2.0 PRO supports your setup with Xbox-X and it supports up to 4K 60HZ. You can still enjoy it under the supported resolution.
You can return it if you still insist on the return but we do hope you can keep it to try our amazing products and save the return shipping fee:)) Feel free to reach out the support team via email.
Best Regards!
