Unclogging a drain typically costs $250, although prices can range from $99 to 750. While we are aware that this is a broad range, a number of variables, including the ones listed below, can impact your cost: the location of the clog.
How difficult it is to reach the obstruction.
How is the main sewer drain supposed to be cleaned?
Steps for Unclogging a Main Sewer Line, sewer and drain cleaning claims The initial step is to locate the main drain cleanout. Take off the Drain Pipe Cap (Cleanout Pipe).
Take off the cap, then let the buildup drain. Once the cleanout cap has been removed, swiftly leave the area. Insert a snake into the pipe. Till the clog is gone, keep running the tool. tidying up
