    r2000
    Mar 20
    LED strip specs?
    Hi all, am curious what type of LED pixel strip lytmi uses: WS2811, WS2812B, other?
    Only thing stopping me from buying one right now is no support for syncing other lights like hue. BUT I really don't want to shell out $$$ for hue. I know that official support for syncing lights is coming, but in the meantime was thinking about way to add more lights. one way would be to use an RGB sensor, another would be to intercept the the RGB(W?) value for a specific pixel and drive an external LED.
    Thanks!
    1 answer1 reply
    Mar 22
    Hello there, I am afraid NEO only guarantee it works under Lytmi light strips. Therefore I suggest you order the whole kit including the light strips.
    Plus, the syncing light bar is on the way and it will be on in the near future. Please kindly stay tuned:)) Thanks for your amazing ideas, and our developing team would consider it and work hard on it.
    r2000
    Mar 22
    Hi, thanks for your answer! Yup still want to buy the official light strip :)
    2 comments
