Same here, I than did install all brackets around 5cm closer to the screen center. Than it is at least a closed loop. But still not as being described as in the manual.. 😕
@Selami Yel could you attach a video clip so we can better analyze the flickering. And if possible could you double check the cables are correctly connected, especially the light strips that covers the bottom of the TV should be connected to the port marked bottom only.
@Jack when i wanted to make a video it suddenly works so no problems so far everything works great thanks for the great product cant wait for the hdmi 2.1
Was a 66~90 inch a better option but i have a 65 inch tv so i bought a 65 inch lighting kit
