The manual says 2 approaches to install light strip Left or Right corner. Has anyone installed light strips starting from middle of the screen bottom, the all the way up to the screen side and to the middle of screen top. Repeat the installation of 2nd strip similar to 1st strip on the other half of the screen. Will there be any issue like lights colors out of sync if installed from middle?. The reason I want to start in middle is because of the USB cable too short from my 120 inch screen when placing the sync box in center of screen.
Mar 12
LED Strips attaching from middle instead of left / right?
1 answer0 replies
Hi there, I am afraid it cannot be installed from the middle. The color won't calibrate with the screen correctly if you start from the middle since the APP does not have the this option for it.
If the cables are too short for you, I suggest you can use 2.0 USB extension cables.
