Hi,
received my Neo yesterday, installation without any problems, App installtion worked.
So nothing special, but:
when i have activated screen mode (ambilight test video) the left and right leds won't work, only very very little. When i do the test, or e.g. Taste Mode all Leds work without any problems!
Removed Neo and added, reseted a few times but always top and bottom very cool, left and right nearly dark.
tried also different HDMI inputs as Fire TV Box and PS4 - same - top and bottom very bride, left and right nealry nothing.
Appreciate any tips - Thx
Maik
IMG_8303
.MOV
Download MOV • 37.87MB
"the current mode does not support color adjustment" means not every mode supports customized color changes as some of them are pre-coded to displayed certain effect using specific colors. The above six modes are fixed and cannot be adjusted. However, the below six modes can be customized.
I noticed you mentioned the taste mode can work perfectly. And all the connection is set correctly. So could you check if it is the media source problem. If it is 30Hz above, it cannot recognize the screen mode. An additional HDMI Splitter will be able to support. Kindly refer to the splitter guidance video: https://www.youtube.com/watch?v=Y6xBLI8FS2M&t=792s
Hi Maik,
Thanks for your message.
Have you checked your video source is equal/under 30Hz? Lytmi Neo supports up to 4K 30Hz and HDCP 1.4 currently. If your video source is higher then that, it cannot recognize the screen mode. An additional HDMI Splitter will be able to support. Kindly refer to the splitter guidance video: https://www.youtube.com/watch?v=Y6xBLI8FS2M&t=792s
If you power on without installing and connecting the light strip, it might match the wrong size.
So, make sure turn on the power supply ONLY AFTER connecting the light strip and HDMI cable, or the synchronization mode CANNOT BE activated.
Could you please try to re-connect the sync box and re- power it again?
