    Armand Welsh
    Apr 12
    Light falling off TV
    Has anyone figured out what to use to keep the lights attached to the TV? My corners and some straights are all falling off my TV after just a few weeks of usage.
    Tried email support, hopefully they have a solution.
    I absolutely cleaned my TV with alcohol prior to fixing the tape. It's just horrible table... In fact, the tape is still on the TV.. it not on the brackets though, which they were pre-installed on.
    3 answers1 reply
    Apr 12
    We sincerely apologize for the unpleasant experience.
    Due to the material of the bracket, its smooth surface has little friction, resulting in the tapes can not be well bonded. It may also affect the stickers life due to inconsistent TV specifications or heat after working for a period of time. Plus, the light strips weight is also an issue for the holding.
    We suggest you can purchase similar clips or holders for the fixing issue. Or you can apply more double side tape for the fixing.
    Feel free to contact our support email if you have any question. support@light-mi.com
    Shane Van Ross
    Apr 13
    do what i did and get the mould from one of the users on here and have more flat pieces ... the weight of the lights pulls the strips off the tv...need more brackets to offset the weight
    Armand Welsh
    Apr 13
    @Shane Van Ross it’s only a 42” TV. No run is more than 5” without a bracket.
    Luis Flores
    8h
    I just put mine on last week and I woke up one day with the entire strip off with the adhesive still on the tv. I bought the gorilla glue mounting tape which is supposed to be strong and was looking good. Woke up this morning with the entire strip off again. The adhesive is still on the TV, so it came off with the mounts still on there. It’s the plastic on the mounts that don’t have enough grip or something. Idk but it’s becoming a problem :/
    4 comments
