I was really excited to receive the 2.0 pro because reviews have been amazing. I was disappointed to find that the lag between the TV and the lights is unusable. Can't see any way of rectifying this so sadly it's being returned to Amazon.
This could be awesome if they could sort out the lag.
qqqq
Unfortunately, the reviewers were given free products. That seems to have impacted their reviews... I couldn't get mine to work for very long (it would freeze after a few minutes), but when it did work, the lag was unusable.
Hiii there,
May I know if you have reconnect the device and repower it? Let the box reactive might solve the issue.
The slight latency exists for a reason. It evolves something like "Softening Algorithms". And the necessity to introduce the softening algorithms, or put it another way, the slight latency is to make sure when the onscreen content changes even rapidly , the lights will sync the colors and effects in a way that’s is eyes-friendly by making a softening transition by reducing the dazzling effects on the eyes if the lights flash rapidly.
There are three screen sync modes in the app you can try:
●Weak Mode: fit best with TV series, cartoons, (advised mode for the young and the old)
●Normal Mode: fit best with movies, games, etc., (mostly used mode for most people)
●High Mode: fit best with games (advised mode for those who has high demand in synchronization effect)
Anyway, thanks for your feedback and the sharing. It would be nice to have video feedback so we can better provide suggestions:))
