I cleaned the back of the tv real well. A week later kaaaplop…the light strip fell down the top and sides fell off. The corner brackets aren’t strong enough. I had to buy more 3m tape but notice the lights sag as well. They are too heavy. I need more mounting brackets !! Can I get more middle brackets? They will keep sagging and pop off again. Grrrrrr.
sorry about this, currently, maybe you can search cable bracket on Amazon, and you will find a suitable one. https://www.amazon.com/s?k=cable+bracket&crid=1B5OKTVJDLHK4&sprefix=cable+brac%2Caps%2C411&ref=nb_sb_noss
trying to find ones that can fit the thickness of the lights...haven't been successful yet. i got some command 3m ones but they are too small.
