Just got the Neo today, and overall, I'm pleased, however, there is a noticeable audio feedback. I'm using a Vizio Soundbar Toslink-ed to a Sony 850D, and have the Neo connected to the Apple TV. Before connecting the Neo, I never had these sound issues.
It's especially noticeable when scrolling the Apple TV menu. When loading or exiting an app to the home screen, it sounds like an electronic space fan noise (horrible description), and when moving around the icons on the home page another noise accompanies it.
Here's a sample.
What's going on here? 🤷♂️
also posted here: https://www.reddit.com/r/dreamscreentv/comments/tbarhl/lytmi_neo_20_feedback_sound/
Hi there, could you turn off the APPLE TV clicking sound to check if it will still have the strange audio? May I know if it happens under any other movies or media? I am afraid it is the key tone comes with your system.
The strange audio only follows when there is audio present. With it disabled, there is no static. I've run other sound tests and it's an extra static that accompanies all sound. It's less noticeable when there is regular background noise and dialogue, but it is there.
Additionally, I'm noticing decreased image quality, blurriness and weird gradients. Will try to capture pictures and post shortly. I'm connecting to a 55" Sony 850D with HDR 10. 4:2:2 and 4K 60 FPS through Apple TV 4K. I disconnected the Lytmi to test, and all these issues are not present.
I found the issue is having the Chroma set to 4:4:4 - when reduced the sound issues don't happen. This is kind of disappointing as this device seems to be only made for low tier TVs.
