Hi, so I've received and installed my lytmi neo 2 sync box. Works great as a sync box. However, when i connect to the app, the color mode doesn't work properly. When i click the tab on the bottom, it comes up with a message saying 'the current mode does not support daylight adjustment'. This is a bit frustrating as I want to use it as a 'normal' light as well.
Is there any info on this??
Hi Tim, this is normal, for some modes it's preset like rainbow, firework...We will separate those customized and fixed modes in future version to avoid this misleading. sorry for the false alarming.
I suffer from the same issue, it works fine as you say as sync box, however it would be nice to be able to set the lights strips to one color for setting mood scene behind the tv. Hopefully this can be fixed via an update
Hi David, for some scenes, they are not customized. Anyway, already forwarded to your suggestions to our IT guy
@Jack This is a wrong translation only, no software problem. The text in English of this popup message should be
"The currently selected Taste does not allow to change colors. Please select in the section "Taste" "Pure" and not "Rainbow", or any other color-mix Taste."
or something similar. If it needs to be a short text, I suggest
"Please first select Pure as Taste."
Hope this helps.
I have the same issue - cannot set colors, as I receive the message "the current mode does not support daylight adjustment". When will this be fixed?
Ok, I think I have found a solution.
The message
"The current mode does not support daylight adjustment"
is apparently a wrong translation from Chinese to English (only). This message pops up when you select the section "Color" in the App, but only if you have selected a taste in the "Taste" section of the App which consists of more then one color/any other Taste then Pure.
I my view, this popup should have the following text:
"The currently selected Taste does not allow to change colors. Please select in the section "Taste" "Pure" and not "Rainbow", or any other color-mix Taste".
I can change the Color of the Lightning Strip when I select in the "Taste" section "Pure".
Hope this helps.
Noted with thanks. I have submitted your advice to our developing team to better improve and optimize it.
