I would like to receive a refund but when I try to start the process on the website it says I cannot do that because the (30 days) refund window has expired. I have waited for this splitter for almost a month (like everybody here) and because I foolishly trusted the claims of Lytmi that it will fix the Dolby Vision problem, now I cannot start the refund process ? This feels like a scam. I wrote an email to support but I'm still waiting on reply.
Like the title says Lytmi Splitter doesn't fix the Dolby Vision. All the splitter does it tell the input device Dolby Vision is not supported so the input device doesn't pass on Dolby Vision. Which means that when you use this Lytmi Splitter you completely lose Dolby Vision signal, so not even DV passthrough is possible.
I have received the splitter. DV works with him (see my report in my post)
Should I connect the splitter to 220V with the cable with MINI USB from the set and using my Adapter ?
Hi, this is Wendell. My advice is to wait for the splitter and take a try. The splitter should work on Dolby Vision. Or I will ask my colleague to process your refund no matter 30 days expiration or not. Hope this help
