I made this...when I sticked in all cables and sourse power then the first diod light on the box and after 5-10 sec - all 3 diods lights (the APP was turned OFF) .
ya, including the power source, usually it's the last resort, and "universal resort" sometimes, and should connect the lights first, output port second, input port third and lastly the power source
If your TV and tv box or other hdmi devices both have CEC, then you have to turn off both the TV and the TV box, if just turn off the TV, then the lights may still stay on
@Jack I do not other connected devices into NEO box. Only TV is connecred. Is it normal or not that the box has 3 lights when the APP and TV had turned off ?
any way all 3 diods light when TV turned OFF
Must HDMI cable from TV be sticked into the port OUTPUT of the box?
RE could you unplug everything..
220V also ?
The same problem. I turned off TV (yesterday evening) but the box NEO has 3 ligths till morning. Is it correct ?
