I have my light strips and hub connected to Wi-Fi. I can only get the lights to engage with music and the scene mode works. I can't get it to sync to my Samsung 70" LCD Model UN7ONU6070F. AC 110-120V-50/60Hz 180W. I see an option to reduce the picture motion in expert's settings, but it didn't work still. So, I am assuming it's not a error within the setup its the specs. This is one of the reasons I bought this unit for the interaction with movies etc. Any suggestions?
do you only use the tv and its apps for films/series? it sounds to me like you are trying to get ambilight sync directly from tv via lytmi neo. ambilight syncro only works with external hdmi players such as avreceiver/firetv/appletv/paystation...
Yes, Sky Q (cable receiver) and all other devices connected to my AVR-Denon and thus connected to lytmi neo pro 2.0 work without any problems, without dropouts or latency. I live in Germany
yeah and it will look a little bit better if i - with the upcoming lytmi neo 2.1 variant - can connect/synchronize additional ambilight lamps (maybe also a led strip on the floor).
Good Afternoon,
Sky Q works?
REAL home theater!!!
