Hi just set up my neo 2.0. How am I able to use it as a normal light strip and set the colours myself. Everytime I try to go to the colour option it says "The current mode does not support colour adjustment" thank you!
Please choose the fire mode to see if the light strip is all on. If the light strip is all on, it means that the plug is not connected correctly and the synchronization mode cannot display normally. Not every mode supports customized color changes as some of them are pre-coded to displayed certain effect using specific colors.
The above six modes are fixed and cannot be adjusted. However, the below six modes can be customized.
Use mode TASTE with PURE ... use the color wheel to change the color
