Dear all.
We would like to extend our sincere thanks to you for the trust you place in us and in Neo 2.0.
After multiple tests before the shipment, our developing team has already found out Dolby Vision cannot be used in Fire Cube and Fire Max. These days we have received some 2.0 feedback for the Dolby Vision on other devices. The R&D team found Dolby Vision cannot be used directly. And it cannot be solved by software upgrade, since it is fixed in the chip.
We are dealing with the splitter solution for Dolby Vision. Dolby Vision could be transmitted to TV through this splitter. Our team will confirm this solution in 2-3 days. After confirmation, for those who have received the Neo 2.0 version, we would offer a free splitter.
Thanks again for your great support and your understanding would be appreciated.
How could you advertise the system as compatible with Dolby Vision if it wasn't? How would your tests not have shown this? I'm sure a lot of people, like myself, only placed an order because it was advertised to support such content out of the box.
This is a massive oversight of your team and very disappointing as a customer.
I appreciate the apparent urgency to find a solution but this should have been done before launch and shipment.
We know false advertising is the end of Lytmi and definitely won't do that intentionly. We are responsible for the issue, and will get it resovled.
I completely agree with this post and feel the product has been mis-sold I am waiting for a response from my mail to the support as to whether my order can be cancelled or returned as it’s not to the specification I was sold.
Hello.
how will we claim the shipment of the free splitter, those who have bought the neo 2.0?
Will they automatically send it to everyone? or should we request it?
Thank you.
Please contact our support via email and attach your order number. We would apply the splitter for you. And arrange the splitter in a week.
Support email: support@light-mi.com
Very thanks.
Will CEC work thru this splitter also?
2.0 version supports CEC full channel, and it does not need splitter.
This sounds like a joke...
I hope this does not mean a downgrade in image quality.
Just pass through the resource.
I sent an email about the spiliter on 16.12. I have no answer. My order number is LM5013.
Thanks for this info and providing a fix. I have loved it so far and am looking forward to having it work in Dolby Vision as well.
Could you not update the firmware of the Lytmi box to not accept Dolby Vision? It seems I can actually get Dolby Vision through the box to the TV, it's just the LED lights that are off color. If the Lytmi box could simply filter out the Dolby Vision signal and just use the standard HDR signal, the colors would at least be accurate on the lights controlled by the Lytmi.
I used the splitter but no Dolby Vision on my LG C6V; anybody else succeeded Dolby Vision with the splitter (so did I do something wrong)?
I picked up one of these: https://amazon.com/dp/B07VP37KMB/ref=cm_sw_r_apan_glt_i_VG9WCEWTSG2BYGGR6Z2W
While it works to get Dolby Vision to my TV, I can't run Dolby Vision and my Lytmi at the same time. The colors from the Lytmi are off which causes things to look weird (blue on the TV outputs green on the Lytmi). So I'm still stuck with using HDR if I want everything to sync and look m.
Con el splitter que nos han enviado gratis, funciona el dolby vision, pero de manera incorrecta. Colores pobres, y tramos sin iluminar en muchas ocasiones. Resulta molesto y desagradable. Además, el resto de contenido sin dolby vision, también se ve afectado en la calidad final del Neo 2.0
Al final conseguí mejores resultados pasando la señal a través de mi barra de sonido, sin usar el splitter, y la señal dolby se convirtió en HDR, y ahora, pese a no ser la solución, el efecto ambilight está mucho más logrado, y los colores no son tan deficientes. No es perfecto, pero al menos se puede usar el Neo 2. 0
