    Dec 16, 2021
    Neo 2.0 ---Dolby Vision Updated
    Our R&D team have solved the Dolby Vision issue. Here is the solution:
    We offered free customized splitter for your Neo HDMI 2.0 version. Dolby Vision could be transmitted to TV through this splitter. Please kindly contact our support via email for the splitter requirement. And attach your order number. We would apply and arrange the customized splitter for you in 7-10 days.
    Support email: support@light-mi.com
    To show our sincerity, we would also offer 15% off lifetime discount.
    Sorry again for the inconvenience we caused.
    4 answers1 reply
    Warpath Thunderbird
    Dec 16, 2021  ·  Edited: Dec 16, 2021
    Hi, i use a fire TV cube.
    Will the splitter also fix the HDR & Dolby Vision issues with this Hardware or is it just for the other Devices?
    Thanks in advance.
    Andreas G.
    Dec 27, 2021
    Does this customized splitter also resolve the ARC-problem?
    Patrick Quiton
    Feb 01
    Is it possible to get the splitter if I ordered off of Amazon?
    elprimerclau
    Dec 16, 2021
    Thanks a lot. I wish all the technical and after-sales services worked that well.
    Thank you very much again.
    Dec 16, 2021
    We are working hard on it.
    Your support and satisfaction are our greatest motivation!
    5 comments
