I am very interested in buying the NEO 2.0. I have 4 devices hooked up to Philips HUE HDMI Sync box. Will this work with a 4k 60hz HDMI switch that will be fed into the NEO? I want to make sure the color isn't washed out. I will also be using this on a 70" TV. Will I need to trim any of the strips from the 61" to 90" kit?
top of page
NEO 2.0 HDMI switch compatibility question.
2 answers2 replies
Like
4 Comments
bottom of page
Hello Robert,
I am afraid NEO only support 1 HDMI in and 1 HDMI out currently. If you have multiple devices, you need the HDMI extention for it. Plus, NEO 2.0 supports up to 4K 60Hz and it cannot recognize higher refresh rate.
For the light strips, Lytmi supports any screen size UNDER 120 inches. All the light strips are cuttable so as to fit the screen perfectly.
Please refer to the guidance video:https://youtu.be/vwK-U548RcI?t=202
