Hi! I would love to add my sync box to Home Assistant. Does anyone know how? And in the app, whenever I want a static colour. The app says that the current mode does not support colour adjustment.
Not every mode supports custom colour changes as they are preset to display certain effect using specific colors. For example, Rainbow.
Please choose the Fire mode to see if the light strip is all on. If the light strip is all on, it means that it is not connected correctly and the synchronization mode is not displayed normally.
Check the LED strips are located correctly.
Check the LED strips setting on the APP.
