Yes, we are getting such feedback from others also. Initially we design it to be 4 sides, but got feedback saying the bottom will affect how the cable goes, so we change to the 3 sides version. Anyway, we will collecting feedback like that and consider to launch an additional option of 4 sides.
hi @Jack , for the 49 inch, will it also be the same sides to be installed ? (left top and right part of the monitor only?).
Since it is very long lengthwise, not having LED at the bottom would be less bright?
Yes
