Hello, I have a problem with the fixing of the led strips: the adhesive regularly comes off the clips. Have you ever encountered this type of problem? How did you solve it? I would like to print with a 3D printer the clips (corners and length / width) are the models available? otherwise, would you have the technical diagram with the quotations?
thank you in advance for your help
Hello, you can use a hot glue gun, in my experience it works very well to anchor the led strip to the tv.
https://m.media-amazon.com/images/I/81PRBcJG+JL._AC_SL1500_.jpg
Thanks for the idea
I had the same problem. I removed the adhesive pads that came with the mounts that kept falling off and replaced them with heavy duty mounting velcro. They seem to be holding up for now.
Thanks, another good idea
Great idea! Our team would take the velcro into consideration. Thx for your valuable suggestions.
There are also some links, maybe it can help: https://www.amazon.com/Command-Clear-Clips-Strips-CL017-13NA/dp/B076ZT3FVN/ref=sr_1_9?keywords=TV+strip+light+holder&qid=1640338957&sr=8-9 https://www.amazon.com/Blulu-Pieces-Outdoor-Adhesive-Decoration/dp/B0816DZ2YL/ref=sr_1_31_sspa?crid=1MNEKTHY7VT0C&keywords=Strip+Light+Mounting+Clips&qid=1640339052&sprefix=tv+strip+light+holder%2Caps%2C376&sr=8-31-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEySlpNR1pDWjhQSUZEJmVuY3J5cHRlZElkPUEwNDY5NjUxUFRUSUVOVjMxTTZMJmVuY3J5cHRlZEFkSWQ9QTAzNTM2MjcxR1hBVVNEMzVNRkFaJndpZGdldE5hbWU9c3BfbXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Thanks for your help. I add this solution in my alternatives.
Same for me I heard something fall, couldn’t find it and then when I turned on my tv…..I re attached them but they now sag. They are just too heavy and need more brackets.
Thank you for your comment, suddenly I posted a solution in the forum https://www.lytmiforum.com/forum/main/comment/61d557ced7e8170016425cbc
Finally, I opted for in-house manufacturing: I modeled 2 parts which were glued with double-sided tape https://www.amazon.fr/gp/product/B01M5H1LNB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Lytmi Support Angle.png (Green) in 4 copies to position at the 4 corners of the TV
Lytmi Support.png (Purple) in 15 copies 5 on top 3 on each side and 4 on bottom
I printed them with my 3d printer, if someone want the STL files tell me.
Can you please share your STLs? Thank you.
@Panagiotis Panagiotopoulos The files are in Thingiverse enjoy https://www.thingiverse.com/thing:5188791/files
@Eric FREGER thanks for sharing
@Eric FREGER thanks for sharing, hopefully the solvest my issues
Enjoy 💚
@Eric FREGER did it work?
