Recently setup my Lytmi Neo after a few months of not using it. Have since changed where I'm living and have a new Internet router.
When I plug in the Neo, all that happens on the Neo box is the power light comes on solid, the WiFi light flashes and the other light doesn't switch on at all.
It also doesn't cycle through the leds like it used to when powered on.
Every Led on both strips around TV just glow/pulse red at a low level.
The reset button does nothing and whenever I try and add the Neo using the app, it climbs to 100% during setup and then says the connection timed out.
Any suggestions at all? I've tried everything else I have found online and in this forum. Is the Neo just faulty/broken now?
Any help appreciated.
Thanks,
Paddy
