    basemfouda
    Dec 15, 2021
    Reset button doesn’t work
    I have the 2.0 sync box, and reset button doesn‘t respond at all when I press it for 5 seconds (or even more) thus the strip lights only turn white
    15 answers24 replies
    Best Answer
      ·  Dec 22, 2021
    For reset button doesn't work problem: 1. make sure all the lights cable are original and correctly connected (the light cover bottom side must be connected to the port marked bottom only) 2. Always make sure, when everything is set, there should be lights circulating for self-check and at the right corner should be red spot light flashing.
    If lights are not connected, or misconnected, the reset button is always invalid.
    Here attached a short video clip for your reference: https://www.dropbox.com/s/x88ewekznkeal6d/Reset.mp4?dl=0
    basemfouda
    Dec 18, 2021
    @Lytmi please advise. All I am getting now is white color regardless of what my NVIDIA shield is playing
    teknoman
    Dec 29, 2021
    I have the same issue...
    Dec 16, 2021
    Please long press the "Reset" button for about 5 seconds until the WIFI indicator and LED strips turn off briefly.
    If it still does not work, please kindly attach a small video of your problem. We would try to figure out the problem for you.
    basemfouda
    Dec 17, 2021
    Here is the video
    Dec 20, 2021
    Could you try the "universal" unplug everything included the light strips, power source way? Sorry for the inconvenience caused.
    basemfouda
    Dec 20, 2021
    @Jack just did that and nothing changes. Still no response to the reset button
    caymans12
    Dec 21, 2021
    @basemfouda I have also tried this unplugging reset with no luck. Just blue lights and one light on the box.
    Load more replies
    caymans12
    Dec 18, 2021
    I am have the exact same issue.
    Dec 20, 2021
    Could you also attach a video clip for better understanding the problem?
    caymans12
    Dec 20, 2021
    @Jack
    Danny tv
    Dec 20, 2021
    @caymans12 any luck, I’m having the same issue
    Load more replies
    caymans12
    Dec 20, 2021
    For me it doesn’t matter what is plugged in or if the tv is powered on. The box is always on and always has white/blue colored lights.
    Dec 21, 2021  ·  Edited: Dec 21, 2021
    Hi Caymans, could you take a closer pic of the light strips, it seems they are not original ones
    caymans12
    Dec 21, 2021
    @Jack the light strips were plugged in. But no matter what the box never gives any kind of response other than turning on.
    caymans12
    Dec 21, 2021
    @Jack
