    jigsawpr
    May 11
    Second HDMI output
    Has anyone use the second HDMI output of a video reciever to connect just the NEO hub??? Should it work??
    2 answers3 replies
    May 14
    It is recommended that connect NEO with your input device and TV directly, since NEO sync box has only 1 HDMI IN and 1 HDMI OUT.
    jigsawpr
    May 14
    But i loose hdmi 2.1 features like this.
    so if my receiver has a second output that can duplicate the first one. would it work fine ? If i just dedicate the second output only to the lytmi box ?
    5d
    AVR may not support two outputs with different resolutions or may not recognize the Neo Sync Box.
    We suggest you use the simple connection without the receiver.
    jigsawpr
    4d
    @Lytmi Thanks for the reply. But is NOT an option not using my Home theater via HDMI is the only way it should be use if not you’re not using like 80% of the features and audio quality. I’ll wait for the 2.1 box better.
    4d
    @jigsawpr Sure:)) Stay tuned.
    5 comments
