    flopse
    Dec 30, 2021
      ·  Edited: Dec 30, 2021
    Skill "Smart Life" cannot be set up / Single color does not work.
    Hello,
    unfortunately I have a problem with the setup of the Smart Life App.
    I want to integrate the Lytmi Neo 2.0 into my Smarthome via Alexa.
    For this purpose, the Smart Life Skill is to be used.
    Unfortunately, however, it always comes to an error message.
    I proceed as follows:
    1. I select the skill "Smart Life" in the search.
    2. I enter the email of the Lytmi account
    3. A selection comes up for which app to set up the shortcut. (Tuya Smart, Smart Life, Light Mi)
    4. I choose Light Mi
    5. I enter the password of the Lytmi account
    6. An "Authorize" button appears, which I click.
    7. I get the error message: "Link to Smart Life could not be established this time. Please try again later
    8. Of course I have already tried many times.
    Where is the error?
    Note: I try this from germany (if it matters)
    And i cant use sigle color function in the Lytmi App.
    When i go into tab "Color" i get this error message:
    The current mode does not support daylighting adjustment
    How can i fix this, this should be possible isnt it? I think i saw it on an Youtube Video and i think it is the easiest of all functions to display single colors.
    Edit: Ambilight Mode and Szenes as Firework works fine.
    Thanks for your help,
    Best Regards
    Florian
    0 comments
    0 comments
