    vishnu1405
    Mar 22
    Software issue
    Hi i have a problem with my 2 devices i got 2 screen strip devices. and 2 monitor with 1 devices each.
    now the problem is that the software dont detact my other device it only detact 1. the other one does not work.
    does any of you have the same problem and howcould a fix this?
    i appreciate the help
    2 answers0 replies
    Best Answer
      ·  Mar 23
    Make sure you have downloaded the software on both devices. Each software can only control 1 PC screen strip light.
    vishnu1405
    Mar 23
    thanks a lot its working now
    2 comments
