    Zips
    Dec 06, 2021
    Technical Question regarding the led strip
    My understanding is the led strip can be cut if it's too long for the TV which will not affect the colors or syncing between the LED strip and Lytmi Neo Sync Box, but If you try to extend the length of the LED strip it will not work because the color will not match the TV as it was answered by @Lytmi in another post, I'm just trying to understand why the LED strip can be shrunk but not expanded technicality speaking.
    Thanks.
    -Z
    1 answer0 replies
    Dec 10, 2021
    Thanks for your message.
    For the LED strips length, I am afraid the maximum size is 120 inch and it cannot be extended. Otherwise the color cannot calibrate with the TV.
    1 comments
