i would like to equip my 100" screen with lytmi. which version is better, the 1.4 or 2.0 in terms of thickness of the tape and flexibility to fit in around the 90° corners (installation on the outside of the frame)?
Looking at getting this for my Projector screen am I to understand that the tape would adhere to the outside of the frame or should it be on the back and if so how far out would you place the screen?
Thanks for your message. For your questions, the 2.0 version LED strips has silicon covers to protect the LED strip from damaging. But the 1.4 version LED strips are thinner.
thx for answer! so in this case its better to go with the 1.4 version due to more flexiblity to attach the strip on the outer frame.
Here is the 1.4 version LED strips:
And the 2.0 version LED strips:
