Permanent makeup is a cosmetic technique that employs tattoos (permanent pigmentation of the dermis) as a means of producing designs that resemble makeup, such as eye-lining and other permanent enhancing colors to the skin of the face, lips, and eyelids. Tattoos are used as a means of producing designs that resemble makeup, such as eye-lining and other permanent enhancing colors to the skin of the face.
Is permanent makeup a tattoo?
Micropigmentation, or permanent makeup, is a form of micro pigmentation that is comparable to tattoos. It requires the use of a needle to insert colored granules underneath the surface of the skin's more superficial layers. Tattooing and medical restoration, which corrects flaws on the skin caused by scars and vitiligo (a lack of natural pigmentation in the skin), are both related operations. Tattooing can cover scars, while medical restoration can correct vitiligo.
THE CONS
It cannot be undone. Permanent Makeup is not the right choice for you if you like to switch up your appearance with new looks every few weeks...
It may raise issues regarding safety...
It often causes discomfort.
On the other hand, if you sum up all of the money that you spend on particular cosmetics, you might find that in the long term, they cost about the same.
It may lose its color.
