I just receive my lightmi neo and whow....
But
Before using lightmi, i have the hability to woke up my tv only by power on my device with it's CEC possibility. Really help full.
But when i cable all this and power on my device now with thé lightmi neo i loose the CEC function.
Now when i power on my device, lightmi woke up, but my tv do not do anythink and i must keep my remote to woke up the tv....
Really frustration, lightmi give more immersive use but with it i must use all my remote to woke up all my device.....
How can I make my lightmi neo to keep the CEC signal trough my tv?
Hello,
I think your problem can be solved by taking this:
www.amazon.com/HDMI-Splitter-1x2-60Hz-l-b-y/dp/B08D9BCX1R/ref=sr_1_21?crid=3O0QH7MKQ8B1R&keywords=splitter+hdmi&sprefix=splitter+hdm%2Caps%2C160&sr=8-21
The CEC can be activated via a solder, pin13 of the input hdmi to pin13 of the output hdmi
Hi Micgui, it's really so kind of you to be helpful. BTW, did you try that? If this can be solved by using the splitter also, that's will be so great.
Hi Jeff, sorry for the inconvenience caused, though hdmi1.4 version is also supposed to have the cec function. However just confirmed with our IT dept., this function is not activated, so yes, you have to use to remote to wake up the tv. Again, sorry for all those hassles and troubles.
Hi Jack
i have the 2.0 and the only issue I have is that the CEC function doesn’t work. i have it connected to Apple TV 4K and fortunately I’m not experiencing any of the HDR and Dolby vision problems that othersare having. My only issue is that when I turn off the AppleTV, the Lytmi turns off but the TV stays on .
Any advice ?
Have you checked your CEC setting on your TV? Could you attach the picture of the CEC setting page on your TV? It might relate to the setting on your tv.
