    Cristian Diaz
    Dec 26, 2021
    Where to purchase just the strips? Do 3 PIN connectors work?
    I've made the mistake of cutting the bottom LED lights improperly. (I did cut on the copper line, but made the mistake of cutting it when the bottom LED was supposed to meet with the other end of the side LED strip. The side LED strip I had let overextend from the side and top to the opposite side. The bottom LED only extends throughout the bottom where it meats the side LED strip on its side of where the bottom LED strip is supposed to extend upwards.) I'm thinking of buying a 3 pin connector to maybe fix the problem, so I them can potentially redo the process and only cut where the manual shows to cut for both strips. Help is very much appreciated.
    Kindly,
    -C
    4 comments
    Dec 27, 2021
    Hi Christian, I am sorry to hear that, but actually there are not good solutions to it. It's not recommended to connect them by your own as it's high demanding and may easily cause further damage and you're not recommended to buy other light strips due to compatibility problem.
    Cristian Diaz
    Dec 29, 2021
    @Jack What if I bought 3 pin connectors? If I used that on the same strip, would that help?
    Dec 30, 2021
    @Cristian Diaz I don't think so
    Jim Smith
    Feb 28
    The easiest way to find brackets is by visiting Amazon and typing wall mounted brackets or the other way is to visit your local hardware shop. Since you’ll require plywood sheets, different screws, glue & much more. To learn more about this process check out our related guides on https://wallmountedhub.com/folding-wall-tables-for-small-spaces/
    4 comments
