LytmiMar 02Hi there,Sure you can as long as it can connect via HDMI output. I have attched the connection diagram for your reference:All the light strips are cuttable so as to fit the screen perfectly. Please refer to the guidance video: https://youtu.be/vwK-U548RcI?t=202 I suggest you can purchase PC version if you have computer. Please kindly refer to the PC version: https://ilytmi.com/products/screen-strip-light
